افتراضي لتحويل ملفات ال PDF إلى مستندات أوفيس Able2Extract 7.0.6.20
ea_soft
25 فبراير 2012
348
Able2Extract 7.0.6.20 Professional Portable
Descrizion del Software
Able2Extract is a powerful and easy tool to convert PDF files into Word, Excel, PowerPoint, Open Office, HTML, TXT, and many others.
Able2Extract comes with an elegant and professional, with all controls easily accessible and fast.
Use Able2Extract to convert files is simple enough, in fact, once uploaded the file to convert, it is sufficient to select the text to convert and click the button on the top bar, indicating the size to get, and once you have the new document in the chosen format. E 'can also convert multiple files simultaneously in the same format through the Batch Conversion.
A fantastic program!
Scheda del Software
Os
:Windows 2003/2008 Server e Small Business (32-bit & 64-bit), Windows Vista (32-bit & 64-bit),
Windows XP (32-bit & 64-bit) e Windows 7 (32-bit & 64-bit) sono supportati
Testato su Xp e win 7 a 32 bit
Lingua: ENG
Versione: 7.0.6.20
Anno: 2010
Genere: Conversione
Data Di Uscita: 30 Settembre 2010
Aggiornato al "19/07/2012"
Pass the file to any folder and run it.
Orario di seed eanda disponibile:
8/23 40 kb
here
here
