برنامج الاسطوانات الوهمية PowerISO 5.3
ea_soft
25 فبراير 2012
348
PowerISO 5.3
يدعم هذا البرنامج جميع أنواع ملفات الاسطوانات الوهمية مثل: ISO, BIN, NRG, IMG, DAA, ...
كما يتيح لك إنشاء وتحرير وتشغيل الاسطوانات الوهمية بإمكانيات رائعة ستراها بنفسك..
كما يمكنك من خلاله أيضا ضغط الصور الوهمية للاسطوانات وتقسيمها إلى أجزاء وحمايتها بكلمة مرور..
ويتعامل مع جميع أنواع الاسطوانات ومشغلاتها CD/DVD-ROM ..
Create, edit, extract, convert, compress, encrypt, mount CD image file!!!
PowerISO is a powerful image processing and file compression tool, which allows you to create, extract, compress, edit and convert ISO/BIN image files, and mount these files with internal virtual drive. And most of all, the compressed files can be used directly without decompressing.
Support ISO, BIN, NRG, IMG, DAA, ...
Open, Create, Edit, Extract ISO File...
• Compress, Encrypt, Split ISO File...
Integrated with internal Virtual Drive...
Main Features:
Support ISO, BIN, NRG, IMG, DAA, …
Open, Create, Edit, Extract ISO File…
Compress, Encrypt, Split ISO File…
Integrated with internal Virtual Drive…
Supports on-the-fly burning.
Supports UDF image file.
Create image file from hard disk files or CD/DVD-ROM.
Edit an existing image file.
Can edit and burn Audio CD image file.
Extract files and folders from image file.
Convert image files between ISO/BIN and other formats.
Make bootable image file, get boot information from bootable image file.
Make floppy disk image file.
Optimize files to save disk space while saving image files.
Mount image file with internal virtual drive. Even if the image file is saved as DAA format, the virtual drive can handle that format directly.
Support shell integration, such as context menu, Drag and Drop, clipboard…
Supports command-line parameters.
Can open XBOX image file.
Supports multiple ********s
Supported ********s: English, Arabic, Bulgarian, Chinese Simplified, Chinese Traditional, Croatian, Czech, Danish, Dutch, Farsi, French, German, Greek, Hungarian, Italian, Japanese, Korean, Lithuanian, Norsk, Polish, Portuguese, Russian, Slovenian, Spanish, Swedish, Thai, Turkish, Ukrainian,
Belarusian
Changes in PowerISO 5.3:
- Some minor bug fixes and enhancements.
here
here
