Windows Xp Sp3 Corporate Student Edition December 2011
INFO
نسخة الطلبة لشهر ديسـمبر 2011
أصلية وكاملة وبالبرامج اللازمة
لاتحتاج إلى سريال اثناء التسطيب
محدثة حتى 13ديسـمبر 2011
تقبل التحديث من ميكروسوفت بدون مشاكل
مفعلة مسبقا ولا تحتاج إلى تفعيل
تحتوى على النت فريموورك الكل فـ واحد والهامة خصوصا للألعاب
Format: Iso || Bootable || Size : 690 MB
[FONT=Trebuchet MS][SIZE=2][COLOR=teal][B]This so-called student copy of XP[/B], it is used for educational purposes and there fore
it is designed for multiple installation without further contact with black-list Windows Genuine Advantage.
This version of Windows XP SP3 does not require activation and is the official validation of Microsoft.
no need for any wga cracks with this one it passes online as fully Genuine (student edition based + proper student key)[/COLOR][/SIZE][/FONT][FONT=Trebuchet MS][SIZE=2][COLOR=teal]
to check if xp is activated goto start/run and enter the following [/COLOR][/SIZE][/FONT] [FONT=Trebuchet MS][SIZE=2][COLOR=teal]
oobe/msoobe /a this windows was made with xp pro student edition sp0 RTM 32bit as the source disk, with Sp3 Build 5512 added and upto date hotfixes added the cd-key is slipstreamed into the cd so no need to put when installing from system bootup
tcp ip = 16777215[/COLOR][/SIZE][/FONT][FONT=Trebuchet MS][SIZE=2][COLOR=teal]
uxtheme applyed
(can use unsigned themes)
Default windows language ENGLISH/UK please change to your own language when installing.[/COLOR][/SIZE][/FONT][FONT=Trebuchet MS][SIZE=2][COLOR=teal]
you can also use 'Regional and Language Options' after if need be in Control panel.
i burned the iso image with nero.. this will just about fit on a 700 MB cdr-rom..[/COLOR][/SIZE][/FONT][FONT=Trebuchet MS][SIZE=2][COLOR=teal]
please do a clean install from system bootup with this windows disk.[/COLOR][/SIZE][/FONT][FONT=Trebuchet MS][SIZE=2][COLOR=teal]
this is not a upgrade disk as those parts were removed.
[B]ADDED TO THE INSTALL DISK[/B][/COLOR][/SIZE][/FONT][FONT=Trebuchet MS][SIZE=2][COLOR=teal]
Framework all in one 2.0 - 4.0[/COLOR][/SIZE][/FONT][FONT=Trebuchet MS][SIZE=2][COLOR=teal]
Internet explorer 8
Windows media player 11
Directx 9 Runtimes June 2010 9.29.1962 (32bit only)
Directx Managed Code 1.1.0 (32bit only)
c++ runtimes 2005 & 2008 & 2010
[B]REMOVED FROM THE INSTALL DISK[/B][/COLOR][/SIZE][/FONT][FONT=Trebuchet MS][SIZE=2][COLOR=teal]
Music Samples[/COLOR][/SIZE][/FONT][FONT=Trebuchet MS][SIZE=2][COLOR=teal]
Tour
REMOVED FOLDERS FROM THE INSTALL DISK[/COLOR][/SIZE][/FONT][FONT=Trebuchet MS][SIZE=2][COLOR=teal]
SUPPORT , VALUEADD , DOCS , WIN9XMIG , WIN9XUPG , WINNTUPG[/COLOR][/SIZE][/FONT][FONT=Trebuchet MS][SIZE=2][COLOR=teal]
ADDED TO THE INSTALL DISK[/COLOR][/SIZE][/FONT][FONT=Trebuchet MS][SIZE=2][COLOR=teal]
Driverpacks base 10.06[/COLOR][/SIZE][/FONT][FONT=Trebuchet MS][SIZE=2][COLOR=teal]
DriverPacks BASE is an integration program that will take individual DriverPacks and integrate them into a local 32-bit Windows source for installation.[/COLOR][/SIZE][/FONT][FONT=Trebuchet MS][SIZE=2][COLOR=teal]
[B]DRIVERPACKS ADDED[/B][/COLOR][/SIZE][/FONT][FONT=Trebuchet MS][SIZE=2][COLOR=teal]
Chipset 11.11[/COLOR][/SIZE][/FONT][FONT=Trebuchet MS][SIZE=2][COLOR=teal]
Cpu 10.05
Lan 11.11
MassStorage 11.11 txt mode
(sata + raid)
Wlan 11.09
Monitor 10.05
Sp3HD audio 00002[/COLOR][/SIZE][/FONT][FONT=Trebuchet MS][SIZE=2][COLOR=teal]
Wireless 00003
THE UPDATES[/COLOR][/SIZE][/FONT][FONT=Trebuchet MS][SIZE=2][COLOR=teal]
(hotfixes)
SFC (windows File Protection) Disabled[/COLOR][/SIZE][/FONT][FONT=Trebuchet MS][SIZE=2][COLOR=teal]
Numlock off default
Classic control panel Enabled
updated windows hotfixes till December 13th 2011[/COLOR][/SIZE][/FONT][FONT=Trebuchet MS][SIZE=2][COLOR=teal]
updated Internet explorer 8
updated MassStorage 11.11 txt mode
(sata + raid)
added Chipset 11.11
added Cpu 10.05
added Lan 11.11
added Wlan 11.09
added Monitor 10.05
added Sp3HD audio 00002
added Wireless 00003
updated Directx 9 Runtimes & Managed Code June 2010
(32bit only)
[B]How To Use[/B][/COLOR][/SIZE][/FONT][FONT=Trebuchet MS][SIZE=2][COLOR=teal]
Burn the iso image using the software you like at a slow speed say about x4 or x8 as this CD is bootable.[/COLOR][/SIZE][/FONT][FONT=Trebuchet MS][SIZE=2][COLOR=teal]
Install as you would an original CD from system bootup.
leaving the disk in the drive and reboot pc.
booting from cd rom drive first before harddrive
If you have xp installed already your advised to backup your graphic drivers first before install. example using driver genius.
as only the above drivers
and basic xp drivers are on this cd-r disk
ScreenS
Download
هنـــــــــــا
رابط واحد سريع يدعم الإستكمال
